Where's a good place to buy my liner for my chimney? Should I go with mostly rigid pipe or all flex? So it's better to seal off the liner at the bottom of the chimney...right? Does that baffle just slip around the liner? I'm buying a quadrafire Castile insert. My hearth is about 3 inches lower than the firebox (inside the fireplace) What are my options there? The dealer said my stove will still fit in there fine, he said it had adjustable legs to support and level the back of the insert. I was thinking of adding a layer of block to my hearth (it's very old worn and dirty) so that could bring it up close to level with the firebox and make the aesthetics better.
My other question is the surround or the panel that seals the fireplace opening. How does that attach? The dealer suggested the steel panel that could be trimmed to fit rather than the cast iron fancy one. I've got rock on the outside of my fireplace so that would have to be cut to fit the cast iron one.
Sorry for all of the questions but I've never done this before! Thanks in advance! Scott
