Hi all,
This is my first post, although I have been lurking and learning for some time from this great site.
I have an unusual project and would like some info and input if possible.
I live in Australia, and we don't have as cold climate as some parts of the US, but my home is in need of heating this winter, it is not long been completed.
Secondly we don't have the take up of pellet burners and boilers to the extend to the US , so sourcing parts etc is not convenient from here but it's doable.
My home has hydronic floor heating installed in the concrete floor, it is currently hooked up to solar water panel that transfers heat into a 400 litre tank that is then circulated through the floor. This is not sufficient to heat the house through the darkest part of winter or in times of overcast weather, but it has done a great job of warming the floor coming into and out of winter. The building also allows winter sunlight into the house for warming on clear days.
The project is to boost the 400 litre storage tank with a pellet / biomass / wheat burner.
I have secured all the important parts from a Harman P43 pellet stove, that is the entire auger feed, burn pot assembly hooked up to a 240v auger motor (Australia uses 240v not 110v).
The burner set-up is going under a 135 litre water heater tank that previously used a LPG gas burner to heat domestic hot water. The heater tank will be plumbed to the larger storage tank with a circulating pump. We call a water heater like this a 'donkey'.
The questions I have initially are easily answered by those familiar to the Harman heater.
1. What is the flame height measured from the burn pot of a Harman P43 at full throttle? (I need to gauge the placement of the burn pot relative to the bottom of the heater tank.)
Constructive suggestions welcome.
For those concerned with safety, both tanks and burner are outside the house, there is a controller with the target temp of the heater at 55 degrees C. There will be some other safety cut-outs added as the build progresses based on a thread from this forum, by 'snowy downs'.
Steve
Steve
