Hello everyone, it's my first time posting here so I'll start by saying hi... "Hi" ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
I apologise in advance, this is a long post as I have a few different questions and worries, therefore I want to explain in detail as I'm quite concerned.
Situation and my concerns:
My elderly father has recently bought 2 pellet burners to replace his old and expensive to run log/coal stoves. He bought them with the intention of just straight swapping them, putting the new pellet burners in the same places the old log stoves were as he assumed they worked and vented the same way. But, I knew they have some differences compared to conventional log stoves, so I started doing some research. Upon doing so I immediately realised he might have some issues and potentially dangerous ones, which is why I'm here.
Plus, to add to the issue, the pellet burners he bought, although a reputable brand (apparently) and brand new from a store, they came with Zero information or instructions, just a generic print off piece of paper saying; don't get water on them, only burn pellets, don't open the door while burning... that sort of thing. So he knows nothing about how to install these burners or their requirements to work properly.
So, my father's home has 2 separate brick chimneys on either side of the house. He's installing the two pellet burners in the same places the old log/coal stoves were and venting them into the chimneys in the same way. He's trying to save as much money as possible because of his pension, so instead of buying the solid steel pipes that the store recommended, he went to another store and bought some steel flexible pipe, called (INOX AISI Steel) whatever that means.
He intends to simply use a piece of this flexible pipe attached to the exhaust on the burner, then bend it 90degrees up, straight for roughly 50-60cm, then a 90degree bend and attach it to a pipe connector cemented in the wall of the chimney.
My concern is, I can only find one or two posts online from people using this flexible pipe as an exhaust, every uses this flexy pipe as air intake but not as exhaust, plus 99% of posts I've read people recommend you use solid steel pipes. I'm worried that if this flex pipe gets damaged with a small tear or hole, it will blow toxic gases into the house. Or, I know it's a type of steel, but as it's very thin would the heat be an issue causing the pipe to get soft or brittle.
One more thing I discovered, was that some pellet burners require an external air intake, which I'm pretty sure these ones require as they have 2 pipe connections sticking out the back of the machine.
But when I told my father it means a second pipe needs to go through the wall to suck air in, he just shook his head and said; "Don't be silly, it will be fine".
I love my father very much, but no matter how old I am he will always see me as a little girl and therefore he assumes he knows best and he knows how to do everything better. I tried explaining what I had read, that without an external air intake the burner would suck in lots of air from inside the house and cause negative pressure, which causes a slight vacuum and can result in gases being released into the house... but again, he just shook his head and said; "it will be fine."
My questions:
So, I guess my first question is regarding the pipes - Is steel flexible pipe safe to use, to connect the exhaust to the chimney, or does it have to be solid steel or double layers pipes??
Next thing - is exhausting directly into a traditional brick chimney OK to do? The internal dimensions of the chimney are roughly 25cm x 25cm if that matters.
Regarding an external air intake, is this an absolute must regardless of the size of the house or burner? Is it dangerous to not have one?
Lastly, for now at least, I read that you need a UPS (battery backup) if you live in an area prone to power outages. Well, my father lives in an extremely rural area and subsequently he gets dozens, sometimes hundreds of power outages every year, some only last 2 minutes, but last winter he lost power around 30 times, a few occasions for 4-5 days straight.
Therefore, would a UPS be needed for safety, not just so he doesn't lose heating, but so the burners don't explode or blowout gases and smoke if the power goes off during the night or while he's out??
Thank you to anyone that reads through this, I appreciate it's a bit of a wall of text, but I'm really concerned about him, he always thinks he knows best and it will be fine don't worry, but he regularly gets things wrong, he just doesn't admit it.
Really appreciate any help and advice, especially any links to helpful installation tutorials.
Thanks again,
Sophie
My questions:
Thanks again,
Sophie
