PEERLESS WB-03-110 BURNING RICH?
pelletizer
663
Pellet County N.H.
My peerless WB-03-110-WPC is burning rich I think?
I have a stronger smell of heating fuel coming from it this year more then ever.
Furnace was cleaned in the fall and have burned about 50 gallons of oil this year (we have a new supplier of oil as well)
I check the inside of the flue through the draft damper and there is a light coating of black carbon and very little sulfur streaks.
Viewing the burn chamber through the 4" diameter hole in the front (covered by a swinging door) the stove is clean inside but there is the coating of black soot or carbon.
Wondering if I should open the air intakes on the Beckett burner that are currently at 7 and get a little more air in for combustion.
It sounds like it is too rich. In my oil furnace opening the air a little would help and I would try that first but is it possible in cleaning that the igniter or nozzle were mis-aligned? There is a possibility oil is dropping/spraying to the bottom or sides of the pot and you are not getting a clean burn. Some times all you have to do is rotate the igniter to adjust the spark so the spray/mist comes into better contact with it.
Just monitored a start up and burn through the 4” diameter hole in the front and the peerless appears to burn with a very full flame, I will try opening the air just a bit, I did notice when I replaced the nozzle it was wet on the bottom but it is like that every year I replace it. will tweak the air open a half.
