peeing tree ID
Constrictor
Ok we cut down a 30" Diameter tree last weekend and having trouble identifying it. I do not have a picture, but its pretty, light white wood with a slight pink/carmel center and the tree peed out water like nobodys business when we cut it. Even the limbs did this. My first thought is elm ive heard about its high water content, but i also heard it splits terrible and this stuff splits nice with no stringys. A guy at work told me that he thinks its soft maple? What kind of tree would literally pour water out when cut?
I have seen soft maple weep even a couple of weeks after it was cut but the wood is not what I would call light when fresh cut or even after it has set for a couple of months. What does the bark and branches look like?
I have never seen soft maple do that! I cut more than 30 cords of soft maple this season
The only time soft maple will do that is if you cut it during spring.
Without pictures, can you describe the bark? Too bad you can't even show a picture of a tree like it as many times you can tell what type of tree it is just by the shape of it. Naturally, there aren't going to be many leaves right now. lol
btw, you will occasionally (very occasionally) find an elm that will split very nicely, so it could be elm.
My dad sometimes referred to a tree called "piss elm" (pronounced elem). Maybe that's what he was referring to. What part of the country are you in?
I cut some black walnut a few weeks ago that poured water out like that, I had never seen it coming pouring out like that before!
I have seen elm do this first hand and when wet is the color you mention.
Have you tried to split any of it yet. You will know then if it is elm if very stringy and you curse a lot while splitting it.
smokinj: Mostly in the spring like Backwoods Savage says. I have seen the sugar maples leak water for some time in the fall too like bondo commented.
Constrictor: I was wondering since it is light in color if it might be some type of willow but I though they were more brown at heart.
My best guess without a picture would be cottonwood. Seems to fit. Cottonwood retains a bunch of moisture, usually has the pinkish center along with occasional pink streaks, has light colored sapwood, and splits fairly easily. I have witnessed water spraying out when splitting.
Boxelder has a very white wood with red or pink streaks. It will also leave it's seeds hanging on the tree all winter. But don't think they grow that big?
Ok i found some pictures the wood split fairly easy and not stringy at all.
  • [Hearth.com] peeing tree ID
YOur first picture the bark sure looks like a maple of some sort. Way to straight grain to be elm.
After seeing the pictures, I can tell you that it is not cottonwood, as I previously guessed. I'm not sure what it is.
looks like i really stumped you guys. The guy at work as an absolute expert on kiln dried wood ( we work at a cabinet shop) so i trust him pretty well but another buddy of mine thinks its a piss elm.
Constrictor said:
LEES WOOD-CO said:
Wormy soft maple.
wormy? is that a species or a condition? is it gonna be good wood?
Condition. Its caused by a combinatin of worms and minerals in the ground water. It usually occurs around wet areas, swamps or river bottoms. Its a medium BTU hardwood. Burn it.
The tree was in perfect condition when we sawed it down and ive not seen any worm holes, maybe i don t know what to look for?
Silver Maple, Definitely not sugar maple for it is very heavy when it's cut. Nice to see you again Lees Wood Co.
