j-takeman said:First I heard of them! Im interested in trying a sample of them. Did you recieve any to try?
28% moisture sounds like to much. Highest I seen corn burn decent was at 18%. We like to see it lower, Like around 12% or so. Moisture is supposed to lower the BTU content. If you notice any of the TwinPort test reports on pellets they usually supply a 0% moisture/BTU rating and the actual moisture/BTU rating.
WoodPorn said:maybe they could replace the inferno's???
Tri-State Pellets said:Getting a couple sample bags sent over. Ill post up some test when I receive them
Tri-State Pellets said:WoodPorn said:maybe they could replace the inferno's???
Replace the INFERNO'S?! I did not know their was a better pellet out there?! Guess you learn something everyday
Why don't they just use Mahogany or teakDMZX said:I have never heard of them, but their numbers look pretty good.
Mining peat bogs is somewhat controversial though:
(broken link removed to http://www.naturallifemagazine.com/0712/asknlpeat.html)
SmokeyTheBear said:Hey how the he double toothpick are they supposed to make LAPHROAIG if you folks burn the primary ingredient ;-) .
the maker of the World's favourite Islay single malt scotch whisky.
j-takeman said:SmokeyTheBear said:Hey how the he double toothpick are they supposed to make LAPHROAIG if you folks burn the primary ingredient ;-) .
bear, What the heck is LAPHROAIG?
Edit: never mindthe maker of the World's favourite Islay single malt scotch whisky.
