Good afternoon everyone,
I had a bit of an overfire last night with insert face temps up at 850+. Things came under control easily once the air was closed down and the blower turned up, but...an overfire nonetheless.
I just went to have an inspection of the firebox and found what may or may not be some cracked welds on the front frame, just inside the door. I can't say I have ever looked for these before, or inspected this particular spot on the insert so can't say if what I am seeing is something of concern or some variant of normal for the PE Super Insert that is in it's 5th season.
I've attached some pics--two from each side, upper right and upper left of frame inside of door. (pics with insulation on the right are from the left side of insert and with insulation on the left from the right side)
Are there any PE experts or fellow owners who might be able to chime in?
Thanks!
![PE Super Insert Overfire/cracked welds? PE Super Insert Overfire/cracked welds?](https://www.hearth.com/talk/data/attachments/251/251509-c62c7e4f8a56e9d8b7ec8ac374225dde.jpg)
Thanks!
![PE Super Insert Overfire/cracked welds? PE Super Insert Overfire/cracked welds?](https://www.hearth.com/talk/data/attachments/251/251504-1c426327e842d23b30e95ce7ad80bf8e.jpg)
![PE Super Insert Overfire/cracked welds? PE Super Insert Overfire/cracked welds?](https://www.hearth.com/talk/data/attachments/251/251505-695868508ed1543b31352c174e97daf3.jpg)
![PE Super Insert Overfire/cracked welds? PE Super Insert Overfire/cracked welds?](https://www.hearth.com/talk/data/attachments/251/251506-e6af93c350d0475b6065a34a36e193cd.jpg)
![PE Super Insert Overfire/cracked welds? PE Super Insert Overfire/cracked welds?](https://www.hearth.com/talk/data/attachments/251/251507-392e035ef2728d0c4100ca45b860f222.jpg)
