Hello there, new member here. I have a question about a PE Summit LE Insert that I had installed last fall.
I did what I thought was ample research into the combustion air, but there's more to it than what I initially thought. I had a full SS liner put into the masonry chimney with a rain cap on top. Combustion air enters the fire box from the front and the back of the chimney has an ash cleanout that is currently closed. The back of the chimney sits in a hallway for two recently finished bedrooms (used to be the garage).
When burning last winter, I could feel the supply air coming from the top of the stove and being directed straight into the floor in front of the unit. Seemed fine at first until I felt the stream of colder air running straight through this supply and back into the firebox where it is wastefully being sent up and out the flue. The manual shows supply air flowing up and away from the unit, not into the floor. The heat output seems less than what it should produce. Is this normal? Should I be pulling the combustion air from the ash cleanout in the back and block off the front, and if so, what about the "boost air" that the manual calls for? I added some pictures for clarification. Any thoughts are appreciated!
Alan
![PE Summit Short Cycle Question PE Summit Short Cycle Question](https://www.hearth.com/talk/data/attachments/260/260640-f7f4e29902a7c3efc40a02070b1285cb.jpg)
![PE Summit Short Cycle Question PE Summit Short Cycle Question](https://www.hearth.com/talk/data/attachments/260/260641-3e87fe580466d631b2a7eea0a9b378eb.jpg)
Alan
