PE SUMMIT old vs new
Peterr
5
SE Ontario, Canada
Hi guys/gals,
Im looking at potentially buying a PE summit insert and came across a used series "A" 2010 that looks like its in good condition. Is there any differences that would effect burn time or ease of operation that would make me lean towards a brand new unit instead?
thanks
EatenByLimestone
7,042
Schenectady, NY
The summit is a good stove. That said, if you dont know what to look for with the condition of a used stove, you could put yourself and your family in danger.
Look for signs of over firing. White marks on the sides, warped baffle, cracked welds, etc.
Also, things such as fresh paint or new parts can clue you in to a stove that has seen rough duty and the owner is trying to hide damage.
I'd try to find somebody knowledgable to inspect it for you. You dont want to find out you made a mistake with 60lbs of flaming wood in it.
begreen
Mooderator
Staff member
Nov 18, 2005
78,683
South Puget Sound, WA
Examine the face of the door opening and look for any cracking in the corners. Examine the firebox for signs of overfiring like a badly sagging baffle, warped brick rails & front air deflector. Note if there are lots of cracked and crumbling bricks. Look for the stove top paint going light grey paint.
Peterr
5
SE Ontario, Canada
I have read about some problems with the old EBT system, Is it possible to get it working as good as the new EBT with some of the mods (foil tape trick, modifying damper etc..)?
begreen
Mooderator
Staff member
Nov 18, 2005
78,683
The EBT1 and EBT2 are very different. The EBT1 works thermostatically on the boost air, the EBT2 works like a barometric damper on the secondary air. One should not arbitrarilly assume the stove needs modification. Foil tape on the EBT1 intake hole eliminates boost air. There may not be a need to modify the EBT1 on a Summit A at all unless draft is strong.
How tall is the chimney?
begreen
Mooderator
Staff member
Nov 18, 2005
78,683
If the insert passes inspection and if you install it, try it out for a season. If the wood burned is not fully dry then having boost air can be a good thing. It's easy to mod if draft proves to be too strong.
Dix
6,203
Long Island, NY
Late to the party !
Check the blower fan assembly. Look for dust build up, cat / dog hairs, ash, etc.
Excessive build up would tell me, that the stove / insert was not maintained.
Ask me how I know about the blower assembly :mad:
