Hello,
I'm new to the forum but have enjoyed reading a bunch of great info so far, thanks everyone.
I recently purchased a new Summit LE EPA 2020 model with fan kit and have some questions on maintaining a hot flue. The stove is in the basement, has 36" vertical off the stove (double wall excel ultrablack) then a 90 and about 16" horizontal into a masonry chimney with a 6x10 clay liner, masonry chimney is about 18' tall to the cap. I have one probe themometer 20" above the flue collar.
I have been following BEGREEN's top down lighting method and I am mainly using dry lodgepole pine and spruce with the odd piece of douglas fir or birch - all has a moisture content of less than 16%.
I can get the fire going great, then shut the air down to about 85% at a flue temp of 500-600f. Typically the stove will hold there for about an hour, then after 2 hours its 400f, then at 3-4 hours its down to 200-250 and will stay at 200f with just a stove full of coals until morning (about 9 hrs after lighting). (I'm monitoring temps with a wifi camera and reviewing the footage in the morning, cannot believe there is not a smart stove thermometer available yet!). I have been leaving the fan on 'auto' at the lowest setting.
With the flue temp is hovering around the 200-250f mark for 5-6hours will it be creosoting the chimney? Is this a problem being that for the first 3-4 hours was in the 400-600 and its mainly just big blocky coals at the point when the temps drop? Its putting out lots of heat and that's not a concern, just worried about creosote.
Any help would be appreciated, thanks.
BCARP
BCARP
