Hi Folks.
I'm about a month into using my new PE Spectrum, and love it. Thanks for all the advice and help in respect to selecting that model, it was a good choice.
My question has to do with how low you set the air inlet valve. I've been starting and refueling with the valve set wide open, then turning it down to about 1/2 open for the rest of the burn. When I turn the valve lower than 1/2 open, the flames eventually die out, and the log kind of coals, eventually leaving unburned chucks rather than ash. I can burn things for a while at 1/4 open, but eventually the fire really dies down. Should I be able to burn with the valve closed all the way down, or even at 1/4 open?
I've got about a 20' double walled stack, and a window cracked open an inch or two within a couple feet of the stove. The air inlet is not hard plumbed, it draws air from the room (and the open window). The stove is in my studio, which is by no means airtight.
Thanks for your input.
Bob
Bob
