I figure it's due, and at $175 for the one in November, it's time to suck it up, Buttercup. I don't want a clog in February, ya know :smirk:
A trip To Homeboy Depot, and I should have all the needed supplies.
It twill not be me up on the roof. But I figure I can handle the insert part pretty well. Sweep has been here twice since install, and I paid attention. The only thing I would do different is take out the baffle before the sweep.
Since the snow, I have had access to less than perfect wood (closer to the house, etc). Rectifying that this weekend, with the heat wave, and all. Still managed to get to 450 - 600 °F before retiring. I don't like the look of the cap. Been there, done that.
I had 2 days of no oil burner for heat to the apartment & hot water as it conked out during the last cold snap (0 °F with the wind chill) , and we still had 60 °F in the apartment and 68 °F in the main house.
My glass has been pretty clean. I'm pretty proud of that
My plan is to take out the baffle (twist & up), the off with the cap, and a sweep, scoop out the creosote, reinstall baffle (vacuum insulation) and reinstall. I am alittle nervous about this, want to get it right. I know it's important, this part. I do know where the pin is to remove the baffle.
Should I remove the bricks, like the sweep does (take it all apart & vauum everything), or can I just do the above. Last sweep was at the end of November. I was burning dry wood until 1 week before Christmas.
Interior chimney, not insulated, not block off plate. When the install was done, they cut out enough of the damper to get the liner in, and left the rest. Much better power this year, as opposed to last.
Thoughts?
Thoughts?
