Here is my new PE FP 30 unit. I would like to connect both gravity vents but had also planned to install a TV above this unit. The vents are supposed to be 67in off the floor and 12in below the ceiling. I could turn them into the room behind the unit which is the master bedroom. Otherwise go above the TV causing the gravity vents to pass through the attic. What would you do? How much heat can I expect from the vents? The unit also has a front forced air vent using a fan. Pic below:
![PE FP-30 Gravity Vent Ideas PE FP-30 Gravity Vent Ideas](https://www.hearth.com/talk/data/attachments/157/157004-6b8b398d18602f1ac2a5f19a6d0d4494.jpg)
