I don't understand how the steel inner is convective and the cast outer is radiant? Can you stove guys explain what they mean? I guess I always thought that both steel and cast were radiant.
Thank you Warren. Is there an actual air channel or "envelope" between the steel box and the outer cast? If so, is this convective air flow passive and is it part of the secondary burn air supply sytem?Warren said:All stoves have some component of convection and radiant. Even your gas furnace has a little radiant...very little. In a stove like the PE, the cast iron outside peices get heated by the radiant inner steel firebox and the hot convection air blowing across their insides. Then if you put your hand near them, you'll feel heat from them and it's radiant heat. Just like any other PE stove. The difference is in how much heat the cast iron retains vs how much the other PE stoves sheet metal outer convection shroud holds.
Gunner said:I've said it before, the "shrouded" or "double walled" PE are convection heaters for sure.
I can only speak for the "classic" models as I have not seen the new alderlea in person but it seems the only difference is they have changed an enameled steel jacket for a cast iron one. The convective properties should be the same.
On the classic's: There is about a 1" air space on the sides and top between the stove body and the enameled shroud. At the back of the stove it is closer to 2" Air is drawn in this super heated air space and out the top...the slots/louvers on the top panel of the stove are not there by accident.
As for marketing BS... A 97, 000 BTU stove sitting 4" away from an ordinary wall and requiring only ember protection for the hearth is not proof enough. Oh well
Warren said:Gunner said:I've said it before, the "shrouded" or "double walled" PE are convection heaters for sure.
Gunner, I disagree with one point. "The convective properties should be the same" I believe there will be a delay in heat output and convection currents set up since the cast iron will take significantly longer to heat up. Once up to temp, I'd say it will be close or even better since the cast iron will hold more heat, thus help create more vigorous currents.
Once out, the convection will continue for a bit longer than a classic PE.
Gunner said:Warren said:Gunner said:I've said it before, the "shrouded" or "double walled" PE are convection heaters for sure.
Warren you may be right...I should have said roughly the same :cheese:
Altho your logic implies that one is letting said stove cool down before refueling![]()
cll said:Im am just wondering if the cast jacket will produce much more radiant heat than the steel one on the classic, PE told me the cast jacket is 1/4 inch thick..
Gunner said:As for marketing BS... A 97, 000 BTU stove sitting 4" away from an ordinary wall and requiring only ember protection for the hearth is not proof enough. Oh well
