Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
Why would my stove use more pellets on 2/9, then it does on 3/9 ? It is pretty warm on #3, but if it is going to use less pellets, then I guess it is what it is. I tried changing the pellet feed and it really does not make a difference...
When it isn't freezing out I run mine on 2-3 or 3-3 and I seem to use a definite less amount on 2. Never even had it on 9 on either setting. I have had it up to say 7-7 and it doesn't seem any warmer than 5-5. I think 6-6 was the highest I ran it for any length of time.
Chris, one more thing to check just for the heck of it. The PDVC is supposed to be set at Mode D. Mode C would make the stove burn more pellets.
If you want to double check it, the procedure is as follows:
1….Start with a cold stove
2…..unplug it
3…..plug it back in.....within 2 sec`s press both blower speed arrows at the same time and then release them.....you will see a letter in the heat range window (If you`re slow and miss the timing just unplug it and start over).
4….If it is a letter C, press the up arrow to change it to D
