Plumber damaged a seal/gasket on our Laddo 21-100. I Googled Laddomat and Termoventiler and no joy. Hope I don't need to order from Europe.
Thanks in advance
Thanks in advance
I'll agree,For any of you looking at installing a device similar to the Laddo, I would highly recommend going with the Caleffi unit.
They have decent distribution here in the states and you will be able to get parts when needed.
http://www.caleffi.com/usa/en-us/ca...circulation-and-distribution-unit-npt-281165a
The only thing I don't like about this unit is the flow rate. (10GPM)
For nearly all residential applications under 160-170,000 btu (50KW) it is fine but it's a bit on the light side for commercial sized boilers.
Thanks for the research guys. Fortunately it's only a gasket this time. Yep, we're making a temp replacement. Looks like I need to order parts from Sweden (that's scary). Does appear to be a stocking distributor in the UK.
Velvet, Up North was Brian Crawford's business which apparently closed upon his death. But thanks for the tip on New Horizons. I'll call Zenon. Appreciate the research. I did a lot of googling and New Horizons never popped up.
Lots of happy Laddo users. You'd think the Laddo folks would have fixed distribution by now. It is an impressive device.
