- Feb 19, 2007
- 156
Part 3 of My Mega-Query: The House Details
Welcome to Part 3 of My Mega-Query: Which Woodstove to Get?
The house the stove is going into is in southern NYS, and is a remodeled, 1890’s farmhouse. Though only 2,000 sq. ft. (not counting its very small, unfinished, boulder-walled basement) there are MANY factors which convince me I should treat the house as more like 3,500 sq. ft.—in other words, that I need a large wood stove.
These “big stove” factors are:
a) The house is almost completely an open plan, downstairs. Of the five “rooms” only one has a door or inner walls on it, (other than the half bath).
b) 80% of the downstairs has oddly-shaped cathedral ceilings, ranging between 9 – 10’ high.
c) Two of the downstairs "rooms," and a good portion of a third, are sitting on concrete slabs. I should explain: the house was almost doubled in size with the addition of “bump out” additions on slabs. (Yes, the floors are very cold in places!) The upstairs is ½ the size of the downstairs—roughly 800 sq. ft. vs. 1,200 sq. ft.
d) The previous owner’s gutting and “bumping out” for the open plan left too little baseboard hot water coverage downstairs, such that the 140,000 btu gas boiler can’t keep the downstairs heated adequately, once the temps get down into the 20’s. The upstairs is warm as toast (2 zones).
e) The insertion of an I-beam, to allow the open plan, created upside down “air dams” on the ceilings, a design which the remodelers carried throughout the downstairs, such that there are multiple “air dams” which will hamper (or stop dead?) heat flow throughout the downstairs.
Despite the low success rate of schemes to move air away from wood stoves, which I’ve read about here, I have a plan to move it, near the ceiling, to the ice cold, concrete-slabbed “bump out” we call a dining room—with its 10’ cathedral ceiling. Basically, I want to suspend a 12” pipe up near the ceiling by the woodstove, and run it down the hall and around one corner, for a total run of 18’. I plan to use a thermostatically-controlled squirrel cage fan. The pipe will be level, and in the warm air near the ceiling, so I figure it has a chance of working. I plan on having it exhaust at floor level, into the cold, slab-foundation, cathedral-ceilinged, three-outside-walled “dining room”—the one with the HUGE glass doors. “Meat locker” would be a better description of this room.
(But my “forced air scheme” is not my question for now—I’ll pester you about that in “Phase II, next winter.)![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
f) We will be using the existing external, masonry chimney, which currently has a fireplace in it, which I blocked off. I’ve read enough on this site to know this is NOT ideal, and that a chimney inside the “house’s envelope” would be best. However, if you picture in your mind a house whose downstairs is twice as big as it’s upstairs, you’ll understand that there is no good place to run a flue upstairs, without being in the middle of a bedroom, etc…. And while I wouldn’t mind that if the rooms were big enough, they are tiny (upstairs), and would preclude having a bed in them, if we did that. So the flue will go into the existing, masonry, fireplace chimney, which I’m guessing was added in the 1960’s or 1970’s. It is lined with tile, and we plan on an inspection, and a to-code thimble installed by a professional, along with a stainless liner, insulated with Vermiculite.
The chimney is a two-flue design, of brick construction and the fireplace flue is tile-lined. The chimney is two stories tall and also houses a separate flue for the gas boiler. There are two, small, cast iron “clean outs” in the basement, under the chimney.
So…I’m confident we need a large wood stove, i.e., 3 cu. ft. or better.
In successive postings, I will go into some general questions I have about the features I feel are important to me, in a wood stove. In later posts, I will ask some questions about the five stoves I am particularly interested in. Again, succeeding posts will have a link back to this post (#3), should you want to refresh yourself about the details of the proposed installation.
I really, really appreciate any time and energy you choose to put into my queries, and I hope that there is enough general interest in my queries, by new and potential wood burners, that no one feels I’m “abusing the privilege” of posting here, just because I can’t say in 20 pages what some writers could manage in two…my Dad always refers to it as “verbal diarrhea” …. I’m hoping not all of you agree with him. ;-)
With much appreciation,
Peter
![shade smirk >> >>](/talk/styles/default/xenforo/smileys/shade_smirk.gif)
Peter
