My Tarm Solo 30 took the place of wood stove in my 16x24 pool room, which is a daylight basement addition to my 26x40 original basement. My storage tank is towards my oil backup, which is at the far end of the house, probably close to 60' of piping away. My heating zones are controlled by zone valves, all driven by a common circulating pump, located by the oil boiler. I would like to have some more heat in the pool room, as the Tarm does a wonderful job of feeding the BTU's it makes into the water, and doesn't give up much heat to the pool room. Heating pipes do run back across the pool room ceiling to feed the rooms above.
One of the old zones is a radiator with a fan that can kick out a lot of heat that isn't really needed where it's located by the oil furnace, and I'd like to move it to the pool room. Rather that extend its pipes all the way to the pool room, could I simply tap a parallel loop complete with zone valve into the pipes that are already passing through?
