The early stoves before 1980 with flat top doors had short pieces of 1 1/2 angle iron called “clips” welded at every other brick. That would be across the back and sides as well. Later stoves had one piece angle iron across the back and one long piece down each side. It should have whatever holds the rear bricks in place
I would not not use it without the side bricks in place. I don’t think any high temp adhesive is going to work inside the firebox. You could try stove and gasket cement, but they will come loose in time if bumped around loading.
You normally install rear bricks first, then sides, the bottom to hold tight. If you cut a piece of 1 1/2 angle iron the depth of the inside, set side bricks in place first. Cut the last one to fit. (Masonry blade in circular saw scores easily and snap) Then install the rears to hold the angle iron tight. Then cut a brick for each front at sides of door to hold angle iron tight to sides. Make sure the long piece down the side has 1/4 inch front and back for expansion. It will grow with heat.
when ash gets packed between bricks they become like one and tighten up like one solid piece.
Hi Coaly. Thanks for the advice! I went out this morning and took additional pics based on what I have read on the sticky threads and other posts. I have added some photos here in hope of determing just what these mean. Photo 1 is the inside of the flat panel door. I remember seeing some post that outlined what this stamp means, but cant re-find it.
![Papa Bear purchased!! Papa Bear purchased!!](https://www.hearth.com/talk/data/attachments/264/264417-9639573d158ef5bf80e975a219236a0a.jpg)
Photo 1.
The second stamp I found was on the back of the stove in the upper left quadrant. DEP4090. Also notice the round knob below it. There is also on on the opposite side. Either this plate was punched at time of construction or someone had a laser eye since they are set equidistant from the sides, top and the exhaust pipe.
One of these tubes removes easily from the stove. Looking at the tube, I was thinking this is copper.. So, off the the wire wheel on the bench grinder, and, aha, it is copper. Recirculating hot water heater attempt?
My immediate question is.. was this a factory option?? (dont really think so) custom order?? (maybe) or done after the fact (someone was really talented.) I should also relate that these tubes are now open into the firebox. whatever function they supported was removed.
Worried that these will have some leakage once I get the stove working. guess time will tell.
Added pic of front door as there seems to be an endless look to these.
Patent # is D 237798.
With respect to the firebricks, I went and got enough to do 1 row (vertical) both sides. I will look to fab long retainer bars and use coaly's approach to hold them in place. Looking at the side walls, I think there was two rows at some point, and then removed. Obviously burned fires after removal. Notice the line imprint on the wall 3/4 of the way up. Need to measure that to see if it matches the A brick length measurement.
Sorry, this post ran a little long. Just interested in learning about my stove and what the experts (practically everybody else) have to offer.
