I've mostly stopped using pallets because I find them tedious to cut up.
But here are some things I do to make cutting them up as painless as possible.
1. I usually use my Bosch jigsaw instead of my circular saw. It takes a little longer, but my circular saw is very heavy, and sometimes I have problems with the blade guard getting stuck as I go from board to board.
2. I usually use my Black and Decker workmate. Sometimes I clamp one pallet on top of it and use that as the work surface. The pallet I'm cutting goes on top of that, and may be slid around for convenient cutting. Other times I work directly on the workmate itself. By clamping down the 2x4 stringer, I can keep things from shifting as I cut.
3. Sometimes I start by leaning the pallet against something, and cutting it in half (that is cut along the middle stringer on both sides of the pallet). That makes things less cumbersome to work with, and there's less leaning involved when cutting.
Anyone else have some tips for cutting pallets.
