Getting closer to my wood stove and chimney install this fall, new construction. Starting to buy the individual parts to figure things out.
I'm doing Selkirk's DVL double wall Stove pipe out of my stove, and into a cathedral ceiling box with Supervent for the chimney. Using the "standard" (vs "deluxe") rain cap with spark arrestor so I can keep birds out. I'd like to paint the stainless chimney, galvanized support arm, and flashing/storm collar black.
I read through some old threads, but some details have made me pause.....I see that Homesaver makes a black paint for stainless, but then found it is supposedly "Not rated for extended exposure to sun." Has anyone used this on an exterior portion of stainless? Any idea how it holds up? I only saw that warning on one seller's site, not anywhere else.....
Should I use the Homesaver Stainless Black on the portion of the chimney below the chimney support (visible inside portion), and then use Stove Bright hi temp above it with a vinegar and/or acetone prep and sanding?
Any experience or opinions here on paint prep and brands for the exterior?
