Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
I have a nice 5 qt cast iron pot that I started using for a steamer, however after about 2 days it started to rust and it was gross! Can I spray it with stove paint to keep it from rusting?
the rust and calcium is likely in your water. You could use use distilled water but its cost prohibitive. Better to just scrub it out every once and a while.
You can use hi-temp paint - rated to 1200 degF. BB stores have it for ~$5 in rattle can. Rust will come back in a couple months probably but you can lightly sand or paint again.
i have a small one that i had the same results with , im thinking about media blasting it at the shop and painting with our stove paint , it pretty well matches already but i think our paint would look fine on the inside, though a rust proof coating inside might be a pipe dream with cast and water
