Painted Metal Roofing for Heat Shield ok?
kwmccrea
9
Toronto
Any idea if using metal roofing that is painted will off-gas when hot? Should I only stick to unpainted?
[Hearth.com] Painted Metal Roofing for Heat Shield ok?
Good question? IDK?
A heat shield where? On the Wall?
What stove?
What distance to the stove?
I would go with bare or stove painted bare metal.
For roofing, there's no problem with insulated chimney pipe going up through it. Metal roofing is typically powder-coated so it may also be ok as a heat shield. However, it's always a good idea to check with the manufacturer. Some metal roofing is coated with PDVF resin.
I don't know about painted, but in case you decide to go unpainted, our installer told us galvanized steel creates a toxic gas when heated behind wood stoves. He recommended 12 gauge stainless steel with a 1 inch air gap.
On a hot summer day, you can fry an egg on the roof. I'd say it depends on your stove clearance.
Installation details are important. Galvanized steel is fairly stable up to 390ºF. Typical wall shielding stays well below that. It's a bad idea to use galvanized for stove pipe because it will easily exceed that temperature, but a heat shield is unlikely to get too hot unless clearances are ignored.
Reactions: all night moe
I'm using painted steel siding for a heat shield. No problems. I even put one on the stove itself with a one inch gap and it's not burning yet.
