I paid $268.92 to have my annual pellet stove cleaned today. I watched the guy do it so I can do it next time. There was a few things I learned about cleaning my Harman Advanced pellet stove.
* I was not cleaning the top front of the stove by the heat exchanger tubes. I had a lot of build up there over the winter.
* I learned I need a chimney pipe brush.
* With the chimney brush and a long narrow vacuum hose the guy was able to clean the chimney pipe without moving the stove and without taking the stove chimney pipe apart. Must be careful with vacuum hose to not hit the sensor on the way in. The brush was pushed through from the outside.
* Both fans in the back of the stove could be cleaned by just removing the back stove covers and the one cover over the right side fan.
* After removing the back stove covers their is a sawdust cover that is easily removed with one wing nut. Very easy to clean the sawdust box.
* After that it was normal cleaning that I did every 3-weeks during the winter.
* The guy doing the cleaning kept saying how the Harman stoves are the easiest stoves to clean that he services.
* Very important to clean all blades on fans. If some of fan blades carry more dirt and weight than it could easily be out of balance and damage the bearings in the fans which run almost non-stop all winter.
Having someone else do the first annual cleaning was a good idea. Not that much more difficult than the cleaning I do every 3 weeks.
Next year I do the annual cleaning.
