Hello,
I thought it would be helpful for some to post about our experience with the PE Super 27 LE that we purchased at the beginning of last season. We have a full year and a half under our belt of use burning mostly full time.
Things we like:
-The stove is top of the line construction and very well built. The baffle is super easy to remove to clean and very well made. You can tell the stove with last for a long time with minimal maintenance
-North/South loading, deep firebox. Makes it very easy to safely load wood into the stove. It is a nice deep stove so if you're like us and don't have exact length splits of wood its loads nicely. We do wish the stove was a little wider for better east/west loading if we wanted to (see below).
-View Area/"flame show"-Fire always looks nice
-Tight clearances. This stove had the best clearances of any stove we looked at. This was one of the main reasons we purchased it.
Things we don't like:
-This stove gets hot and gets hot fast! This has been mentioned many times on this site that this is an "easy breather" stove. For some with short chimneys and in milder climates this is probably desired. For us, we have a 16ft chimney and it frequently gets below zero here and It is very difficult to keep the stove under control. We have plugged the "air boost" hole which helped. For us personally, this stove is very touchy and requires near constant monitoring. Many times, the fire is roaring and difficult to turn down or it is snuffed out from turning down the air intake two quickly. In our experience, there is a very, very small sweet spot of when to turn down. Miss it or turn down too early and you're playing catch up or starting over. I don't tend to agree with some on here that this stove is "super easy" to use and control as this has not been our experience.
-Could be a touch wider for better east/west loading if desired. You need to have pretty small splits if you want to load east/west with this stove. Getting pikcy here but I think that would help with the stove taking off.
-We have issues towards the end of the "reburn" with the flame going in and out completely sometimes. You can hear something inside the stove clicking/popping trying to keep it going. The stove pops and flame flares up and down over and over until we adjust the air inlet. This is after it has burned nicely for quite some time so I'm not sure what the issue is there. Maybe it has to do with the boost hole being covered.
Our house is very small (1150 square feet) and the stove sits in open LR/Dining Kitchen. I know we will constantly battle keeping the temperature from getting very hot because of the size of our home but I don't think I would purchase this stove again because I find it burns too hot and drafts too hard for our particular situation. If we had a larger space to heat where we didn't have to worry so much about keeping the stove from getting so hot the super would work very well. Overall, it is a great stove but I think it is very important to look at your chimney height and potential draft with this stove because of how well it burns.
If anyone has any specific questions feel free to reach out. Everyone on this forum was very helpful when we were learning how to use this stove. We still have some learning to do but I hope this helps someone if they are considering a PE stove.
Things we like:
