Hello all,
Just bought and had installed a PE Alderlea insert about a month and a half ago and it has worked great so far except for about a week ago ....
Stupid me jammed a log into it and lifted the baffle up quite a bit on one side, so far that the opposite side almost fell off the rail that holds it up on the side.
Ever since then I am having trouble getting good secondary burn like I have in the past. No change in wood or anything. Wood has been C/S/S for 3 summers and measuring 15-18 percent on the MM after a fresh edge is split and exposed.
A good majority of the secondaries that I am able to achieve is in the way back of the baffle, not around any of the drilled holes but rather between the bottom of the baffle and the back rail that it looks like it is sitting on where the key to remove the baffle is.
Here are some pics to show what I am talking about....
I have yet to take the baffle out of the stove to see if I messed some sort of gasket up or something. I figured I would post here to see what everyone's opinion was before I remove it.
Thanks for any help,
Scott
Scott
