Hi all, I am just now starting to run my new P68 on a some what constant use. If I understand correctly how the controls work, when running in stove temp mode I am feeding pellets at a constant rate. The number scale on the temp dial goes from 1-7 with 1 = 1 lb per hr, 2=2lb per hr and so on. So if I run the stove in stove temp mode set at 1 I should expect to run around 40 hrs per 40 lb of pellets. I have been doing this for the last three days and find I am only averaging around 22-24 hrs per bag ( 40 lb) of pellets. I have been running the stove set at, stove temp in the middle between L and H, feed adjuster dial at 4 and temp dial at 1. The stove is clean ( I gave it a good cleaning) vent is clear and I have tried a couple of different brands of pellets. Am I not understanding how all the controls work , is there something else I am missing or is this about as long as I can make a bag of pellets last. Do your stoves last longer on a bag of pellets?
Any input you can give me would be greatly appreciated
Thanks
JB
Thanks
JB
