Stove temp seems fairly normal but room temp is going nuts. It's not even as cold out as it was and really nothing has changed in the house. Last night was 18 deg and this morning over night it got down to 13. I used pretty close to 70 lbs of pellet in this 12 hour cycle ( 4PM to 4AM). I got up to an empty hopper, the last few pellets going down the shoot.The house stayed at 71-72 but where is this extra heat going ? I'm thinking maybe up the chimney. I didn't use that much in single digits and near 0 outside. I guess I'll have to get my hands on a draft meter. I do seem to burn a bit lower fire size in the stove on Energex hardwood pellets, these were LG last night. I even plugged some holes up in the basement over the weekend.
Yesterday in stove temp it burned half a hopper load , that's more normal usage if not a bit low use. Got a little mystery going on here, cause the house should be well baked with eating that many pellets in 12 hours. Obviously, the probe is calling for heat. But used to use maybe 2/3 of a hopper in the same conditions. Then 3/4 , now the entire thing. I thought 2/3 was a bit much actually with 1800 sq ft of house.
Now hopefully I can get a path to shed and get motorcycle on lift and tear into getting the new cylinder installed for the riding season in two months.
Good heads up.
