I have a harman p38 and I bought a skytech 3301P programmable thermostat and tried hooking it up with no success.
The thermostat itself is working, I check across the wires while not connected to the stove via an ohmeter and it turns on and off
as expected. But with it connected to the stove, the stove acts as if the thermostat is on all the time. It goes to turbo mode and
just keeps cranking out the heat.
The manual simple says to connect the thermostat to the 2 spade lug connectors, which I have done. It acts like it needs a pull up resistor or something...
If I turn the thermostat to off mode and connect it to the stove with it still off..it stays off on the stove ..I hit the on mode and
it goes to turbo as its supposed to, but I then hit off and the stove stays in turbo instead of going back to front panel settings which Is
what it is supposed to do when the thermostat is satisfied.
Has anyone had any success hooking the skytech 3301P to the P38 harman??
