Hi folks. This is my first post here. I spent several weeks researching online and in a few different B&M stores and came up with the Harman P35i. It's going into an existing fireplace that the previous owner used for a wood burning stove.
Right now the damper has a hole cut in it which I think will fit my flue pipe. I do have a few questions though since I have never used a fireplace or installed one of these.
The flue cap- how do I secured that to the top of the chimney? With the high temp silicone? Right now I have a screw on grate just to keep water and animals out.
The Harman instructions say to insulate the flex pipe between the stove and the damper. They recommend kaowool which I've never heard of before. Can I pick this stuff up at HD or Lowes? Is any fireproof insulation okay?
Lastly, I have about a 1" drop between the front of the fireplace and where the insert will sit. Should I level this with something? My concern is that the stove won't make that clearance to slide out for maintenance. Attached is a picture of how it sits now. You can see the slight drop in the picture.
![P35i Installation P35i Installation](/talk/proxy.php?image=http%3A%2F%2Fi.imgur.com%2F5XErDaL.jpg&hash=6e817e5f3782ef47d321ee1f6a546288)
