E
		elkimmeg
Guest
For most of us the cold has not arrived yet. Most will try to get the most heat out of their stove effectively shutting down your forced hot water zone or zones.
Have you thought about some sort of freeze protection. Many times hotwater pipes are routed in exterior walls and at times threw overhangs.
If the water is not circulating, all it takes is one sliver of cold draft to freeze your pipes. Since you burner cycles far less, water will be sitting in your pipes with
out movement a lot longer. It is possible these freezing condition existed but circulation never allowed the exposure time to freeze your pipes
In comes that wood stove, it is so effecient heating the zone it is set in, that it the thermostat rarily calls for heat.
There are three know ways to adviod freeze ups,
One would be to install a freeze alarm to warn you ahead of time freeze condition have deen detected.
The second way to prevent freezing pipes it to charge the system with antifreeze
Third, find the temp setting of the thermo that allow enough flow to prevent freezing. This will take time and experimentation and is not as fail safe as the other two
Having auto setback thermostats and wood stove really increases your chances of freeze ups.
Knowing the sounds made by normal burner opperation can also alert you. IF you hear loud banging pipes noises, That is from rapid expansion and contraction,
when hot water bumps into cold water and pipes. hopefully not frozen already.
