Brazed plate heat exchangers can have a tremendous impact on pressure drop.
I'm trying to build an [open] -> [closed-w/storage] system. on the hot-side I wanted to use a single variable speed Δ T circulator, with zone valves, to control 4 circuits ranging from 18000 to 45000 btu. My wood boiler is 120kbtu/h peak.
My newbie brain can't see anything wrong with upsizing to a "240,000 btu\h" heat exchanger at various flow\pressure scenarios to keep the head pressures in a range that avoid having to buy an industrial sized circulator.
I guess what I'm asking is.. can I size a heat-exchanger to a circulator's\circuits max ranges - using HX pressure\flow specs?
