Hi All
I remember reading once that oversizing your radiators, say by 15-20% gives you more flexibility on the temperature of the water. Allowing you to drop down to lower temps. I guess the theory is that the more you drop away from the ideal temp of 80degC then the less kw output the radiators achieves so you need a bigger radiator to make up the difference....
Bigger always is better right?![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
