I have a fireplace that violates most of the rules discussed in this article:
http://www.woodheat.org/best-practices.html
The firebox is a manufactured metal box about 18" deep and 42" wide with a triple lined straight flue pipe inside an uninsulated framed enclosure which is on the outside of the house. The flue exhausts above the ridge-line. Even though the house is 23 years old, I built it to minimize air infiltration and it is still tight. The few times I built an actual fire, smoke filled the house which I attributed to very little available combustible air and dense cold air in the chimney. Regardless, it smokes which is why soon after I built the house, I installed gas logs which I rarely use because it sucks propane and produces very little heat. While the fire is nice to look at, the pleasant thoughts are extinguished by the thought of my 500 gallon propane tank draining.
Will the new wood burning inserts be able to overcome my poor drafting issues or will I be better off with a pellet insert with forced air exhaust?
