First, thank you all for your many contributions that have answered my questions over the last 5 years.
I have increasingly successfully been using a Jotul 500. This year I added an outside air intake system using a Jotul adapter and connecting a 3" foil flex duct. This stove sits on the hearth of a wood fireplace, so the flex duct runs down the large ash dump with insulation around it, the ash door removed and screen covering the door to keep critters out.
The outside air system significantly reduces the amount of intake air and chokes down the stove.
The stove has to sit on short legs so there is a mildly tight bend (not crimped), then 18" of run, a 90 bend down, then 28" of drop, a 90 bend , then 6" of run then open to the outside air
When the chimney cleaner came this fall to clean and inspect, he said it looked like it should run fine, but so far it doesn't.
I have disconnected it and it runs like old times, reconnect and chokes down, currently disconnected and burning well.
When disconnected, there is a good strong draft pulled through the intake hole on the bottom of the stove, but in my feeble mind its not more than can flow through this duct.
But then research happened:
A decent fire going and no cold air intake hooked up shows 730 cfm entering the intake hole according to my fancy flow meter.
Maximum cfm according to the interwebs through a 3" flex duct is about 400 cfm
So now what?
Thank you in advance for thoughts or advice
So now what?
