I was thinking of adding outside air for the combustion to my XXV. Is there a limit you can run the pipe for outside air? To get to the outside without going through the roof I would have to go around 23 to 25 feet. Or can I go into the attic and pull the air from there which would be around ten feet? I want to eliminate the draft that the stove is creating and from what I been reading this would help.
My house is a little over 2400sf one level mostly open so there is a lot of attic space and the roof is vented and there is vents on four side walls also.
