Hello all,
I am new to the forum and new to wood stoves. I am installing my first wood stove, a Drolet Escape 1800. I'm excited, but also apprehensive because there is a lot to consider. I have been considering how to heat my home with wood for the past few months, and am finally ready to start making it happen. I want to do an corner install for the stove. Drolet says with a corner install the back corner of the stove has to be 7' from the wall. My plan is to remove the drywall on each corner, install cement board, then stone surface. Then, I'll place the stove 7' from the back corners of the stove to the surface of the stone.
My question is, there is an electrical outlet on one of the corner walls. Is there a problem with removing the plug in portion, capping the wires, and leaving the box with the capped wires inside? I want to eventually remove the wire, but may not get to it for awhile. I think since I'll be the recommended distance from combustible surfaces it won't be a problem, but I wanted a second opinion. I've posted a picture for reference. Thank you.
![Outlet behind wood stove Outlet behind wood stove](https://www.hearth.com/talk/data/attachments/303/303628-cee201454f114cdb3aafb32fd189fc1a.jpg)
