Okay, so I've been running my 1800 insert for a month now, almost every day and it's doing most of the heating for my place. I have a 15' chimney, and I'm running an uninsulated liner since the chimney is not exterior one but is central to the house. You can see a video of my install here for further questions about my setup: https://www.hearth.com/talk/threads...1800-chimney-liner-and-blockoff-plate.183133/
One thing I have noticed is that due to my install, my air control lever is bent at a 90 degree angle straight up. It actually came bent like this, probably for the exact same reason that I have it bent: When you install an 1800 into a typical chimney, if you want to line up the output duct with the damper, it will LIKELY be inset into the fireplace opening, so there is not enough lateral room for a horizontal lever.
One thing I think is weird, is that if I damp the lever all the way down, the fire still just does whatever. I don't feel like I have the ability to put the brakes on a fire, in anyway, it just does whatever. If I open the air control lever up all the way, I can get it to run faster, but it just seems like it is chewing through wood and is not very efficient.
Then I found this thread, and this guy is describing a LOT of what I am experiencing:
www.hearth.com
I was hoping to find photos of what he was talking about, somehow limiting the air inlet so that the air control lever DOES something. What compounds my issue is that I am not sure about the travel of my air control lever because I don't know if the bent portion is in the right place. Hard to explain but here:
I have no idea where the actual opening is, so I have no idea if my plate on my air valve lever is fully closing this opening, or not, but it does seem like a very loose fit. I can remove the air lever and rebend it in a different location, I'm just not sure where it SHOULD be bent. I realize this is a compromise.
Also, I have never seen above 450 on the magnetic thermometer, which is located right above the door on the front face of the stove, so I'm not really worried about it getting too hot.
What I have now works... but it seems like I am unable to get a slow, lazy flame, even with the air valve closed all the way.
Osburn runaway?
Had my 2400 insert running with the stovetop running around 400 degrees yesterday. Threw in about 4 or 5 pieces of wood and the top went to 600 degrees. This made my poor wife a wreck. Air control was all the way in. It's hard to believe there's no way to shut it down any further. My question to...
![www.hearth.com](https://www.hearth.com/talk/styles/hearth/hearth/hearth-logo.png)
![Osburn Runaway Part 2 Osburn Runaway Part 2](/talk/proxy.php?image=https%3A%2F%2Fi.imgur.com%2Ft4WSmG6.jpg&hash=0850afdcf65980d898f991e3326396b1)
