I installed this stove 12-4-2008 and on the first burn I got the exhaust fan scraping something metal. I removed the clean-out plate and can see the fan clearly. it is not hitting anything. So i push the electric motors fan shaft and it goes in about an 1/8th inch (this is normal for a electric motor) and spin the fan by hand. noise is gone. when i pull out the noise returns. So it looks like the fan and motor assembly will have to be removed to see actually where the noise is coming from.
I did check all the screws and all was tight.
If anybody else has had this problem, I would like to know if they sent you a new fan assembly or if they sent a tech out. (probably to grind something off which i could and prefer to do myself as so it will not void the warranty and i know everything is sealed back up again.)
I have been reading these forums for about 4 months and this brand does not seem to be a popular one.
