First off thanks to everyone on this board for their thorough instructions on installations. If it wasnt for this site i would have never attempted to do this myself. It is very much appreciated.
Now on to the installation, it was by no means easy but I took my time and managed to get it done without killing myself. Hardest part was lining up the liner adapter to the flue collar of the insert. But once i got it seated properly it fit snug and the self tapping screws held it in place.
Also, I cant recommend Shoulder Dollys enough. Me and my brother in law lifted that 500lb hog from my garage around to the front door and into my family room pretty easily. They are rated for 800 pounds and i believe it. Best $40 I ever spent.
At the advice from you guys I stuffed as much roxul into/above the damper area as i could and then put in my block off plate. And then stuffed roxul around the sides and back of the firebox. My masonary firebox is pretty large (about 35" across the back) so i wanted to stop as much loss around the back and sides as possible.
I had the first break in fire last night. Burned some pallet kindling and got the stovetop temp up to 250-275. Is there anything I should be on the lookout for with the first couple burns? I didnt smell any smoke (just the paint curing) and my insulated chimney liner (16' exterior chimney) seemed to be drafting well. I'm trying to get the hang of the air controls. Any advice would be appreciated.
My wife loves it. Although she didnt understand why we couldnt get the temps up to 500 degrees on the first burn
Sorry at work now so no pics but I'll upload some tonight.
FYI to all the DIYers.... DO NOT screw the door faceplate screws in with an impact driver
!! You will shear off the head and have to redrill/tap another hole and lose an hour of install time. Ask me how I know!
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
