Hello, I’ve been lurking around this forum for a while now trying to troubleshoot my boiler issues with no avail. So I’m going to attempt to explain my situation here.
I have a Orligno 200 25kw boiler that I bought unused from an estate sale. It is manufactured in 2012 but hasn’t been installed before I did 2 years ago. I found out quickly that no plumbing and heating contractors in my area were familiar with gasification boilers, and I only found one company that was willing to attempt it.
They installed the boiler with a circulation pump that only kicks on after the boiler reaches 150 degrees in lieu of a laddomat or similar setup. The routing and circulator pump setup they used is fairly confusing to me. I’ll attach a few pictures. There is a small 100 gallon stainless accumulator tank that was used in the previous boiler setup, and a small electric boiler setup in conjunction with the wood boiler, but the electric boiler is not used.
The problem I have is the boiler is constantly choking, or “chuffing” or experiencing small internal explosions for lack of better terms. It ends up blowing smoke out of the flue pipe seams. Sometimes it’s strong enough to blow open the damper flap at the back of the wood chamber. There ends up being a lot of chunks of ember blown into the lower chamber. It’s alarming and dangerous to have this thing acting up in our basement of our home.
The stove pipe is connected to a 25’ clay lined chimney, 6”x10”.
Wood is stored in the basement with the boiler and is very dry.
Any help would be appreciated. I’m close to scrapping this thing so I don’t burn my house down. Thanks.
![Orligno 200 EKO 25kw troubles Orligno 200 EKO 25kw troubles](https://www.hearth.com/talk/data/attachments/308/308842-62488e6c882d5a47ecb62bbc16911eb3.jpg)
![Orligno 200 EKO 25kw troubles Orligno 200 EKO 25kw troubles](https://www.hearth.com/talk/data/attachments/308/308839-4b3b94e3c180187d467e0074dbd7ecba.jpg)
![Orligno 200 EKO 25kw troubles Orligno 200 EKO 25kw troubles](https://www.hearth.com/talk/data/attachments/308/308840-2f83e112b135bbeee4c17bc784b20a48.jpg)
![Orligno 200 EKO 25kw troubles Orligno 200 EKO 25kw troubles](https://www.hearth.com/talk/data/attachments/308/308841-74cce4d9044d40509ac3c1e7f1d6d343.jpg)
