Hi, first post, been doing a lot of reading though. Always too much info to take in when starting to research options.
Looking to add-on a wood heating solution solution to existing LP gas furnace. Currently not living in the home full time, but will be in 2026, hence starting to research ahead of time.
Near North Bay, Ontario, Canada
Started searching for gasifiers, outside wood boilers units, (Heatmaster, Polar), then indoor wood boiler (Froling, Autonom, MBtek), then indoor wood furnace (Kuuma, Drolet. I have messaged Kuuma to see if they have a distributor in Canada, as the VF-200 sounded interesting if it is available)
As I already have a propane furnace and duct work, I am looking to add a wood option to reduce the cost of propane, as its getting even more expensive up here with our carbon tax added in. ( I figure it could be $5kin propane to heat for a full year at todays pricing)
Not a big place to heat. 1200 sf, main flr, 1200 sf basement, Would be either a water to air heat exchanger in ductwork for boiler, or parallel the LP furnace and wood furnace into existing ductwork. Propane would stay as backup in case we are away for extended period and fire goes out.
Cost is not the driving factor, but don ‘t need to have the best just because. Easy of use for wife is also big consideration. As is using less fuel.
Can anyone add anything to my already exhaustive searching that might help me decide the best route to seriously consider.
