Hello
When do you run your pool filter?
I am trying to find the best time to run thepool filter with timer.
They say 2 cycles of water change is minimum for 1 day.
So you take the gallons from a pool water https://www.orcity.org/sites/default/files/swimming_pool_water_estimator.pdf
This 18 ‘ round 52” high pool is 16,600 gallons
Divide by the filter pump flow rate, so for my Haywood 1.0 HP motor and 2” hose about 52 GPM which is 3,120 GPH
www.poolplaza.com
16,600/3,120 = 5.32 hours for 1 cycle and 10.64 hours for 2 cycles so at least 11 hours per day and the more night time hours when electric rates are low the better, but should be on when the pool is in use. Since we swim mostly after work then
4 pm to 3 am in the morning may be a good plan?
On weekends if we swim earlier then I can flip the lever to on earlier in the day.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Any comments?
![www.poolplaza.com](/talk/proxy.php?image=https%3A%2F%2Fpoolplaza.com%2Ffiles%2Fig-residential-pumps_2nd.jpg&hash=0cf28c4b178b84e61b0aaa0daacdb20a&return_error=1)
Pool Pump Sizing - PoolPlaza.com
How to correctly size a pool pump for your swimming pool
![www.poolplaza.com](/talk/proxy.php?image=https%3A%2F%2Fpoolplaza.com%2Ffiles%2Ffavicons.png&hash=de1df25a3c6b1df8e7ffab6b47c087cb&return_error=1)
Any comments?
