Hello,
First time poster here. I built a small cabin (14X20) with 12 to12 (45 degree) roof and a half loft. The stove pipe is going through my loft joists switching to chimney pipe in accordance to the code, then going through my roof rafters. I’m pretty sure I have all the correct adapters and boxes since I bought it all from a local store.
Problem is roof rafters are 24 inch spacing and loft is 16 inch. The openings do not line up in the spot I want to put the stove and since it’s a very small space I really do not want to just move the stove over. I thought of 3 options. Obviously the best option would be changing the direction of the pipe after it went through the loft but I’m not sure if that is possible since it needs to turn a lot in such a small space. Also I’m thinking that option is quite expensive.
Note: I am aware that I put in the loft box incorrectly in the photo but it’s just to show how much space I have in the loft and the amount of offset needed.
Note 2: with the floor insulation added in the future the bottom of the loft joists would be about 7.25 feet off the first floor.
Appreciate the help. I am quite cold at this point.
![Opinions on stove pipe placement? Opinions on stove pipe placement?](https://www.hearth.com/talk/data/attachments/286/286406-c95dd37fbf95ee9e834e65a5e5614303.jpg)
![Opinions on stove pipe placement? Opinions on stove pipe placement?](https://www.hearth.com/talk/data/attachments/286/286402-0143157c5c4154a390117eabc1fe78c4.jpg)
![Opinions on stove pipe placement? Opinions on stove pipe placement?](https://www.hearth.com/talk/data/attachments/286/286403-9d5e30485d11c5d6699e8fd61a3d527e.jpg)
![Opinions on stove pipe placement? Opinions on stove pipe placement?](https://www.hearth.com/talk/data/attachments/286/286404-fb89c51d4e313f9b256bc5214750e020.jpg)
![Opinions on stove pipe placement? Opinions on stove pipe placement?](https://www.hearth.com/talk/data/attachments/286/286405-8101a5a723f54effed9ffe5afdf68316.jpg)
