Well guys. I have my 1250 gallon stainless storage tank and heat exchanger...... I used black iron pipe to plumb it all and cast iron circulators.. I had some anti corrosion chemicals from WoodBoilerSolutions that I was going to put in, but in the mix up last fall never got it in.... No probs for one season I thought... WRONG!
I pulled the system apart yesterday to replace the cast iron wye strainer with the brass one I'd bought that was back-ordered half the winter....... And that's when I found the scaly rust and brown water...... I've drained it all out, but I've got to do something now. I suppose I could just flush it out with some water to remove the loose stuff and then fill and put the anti-corrosion chemicals in to keep it from progressing further... Or I could run cleaner of some sort and get the rust out..... I talked to Cozy Heat today (they handle the WoodBoilerSolutions products) and their scale & rust remover is $110 for 5 gallons, and I'd need 65 gallons at the lightest concentrations recommended..... Waaaaayyyy too expensive. I can replace all the plumbing for way less than that (probably for the price of 5 gallons to be honest...)
Then I remembered that acid will remove rust. What do you guys think of filling the tank with water and a gallon or two of muriatic acid? Circulate for a day and then drain and flush...... Or just forget it and get clean water with anti-corrosion chemicals in it and keep moving......
