Without getting into factors (wood type, sun/shade/covered...blah blah), would two year dried wood be *much* better/drier than one year? How much more will it dry out during year two?
Thanks in advance![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Thanks in advance
The time really doesn't matter. The only thing that matters is moisture content. In the right conditions wood can easily be ready to burn in a year. The same wood under different conditions will rot before it dries properly.Without getting into factors (wood type, sun/shade/covered...blah blah), would two year dried wood be *much* better/drier than one year? How much more will it dry out during year two?
Thanks in advance![]()
One two or three years doesn't make a difference as long as you get to the proper mc. If you do something like a solar kiln which can get wood well below 20% in under a year the extra time won't matter.You will see a marked difference from 1 - 2 years with hardwoods. 3 will make you giddy
Top covering also has an effect on seasoning. I top covered this seasons FW this spring (already CSS for 1 year), and there is a noticeable difference in the process. I got a little lazy the year before and had to speed things up.
For top covering, I highly recommend shower curtains from Dollar Tree. I get 6 months to 1+ year out of them![]()
Better yet, use better quality shower curtains when they get too grimy from the shower, then you get several years of a second life out of them.For top covering, I highly recommend shower curtains from Dollar Tree. I get 6 months to 1+ year out of them
Yes, you will notice the difference between one and two years with hardwoods. Easier lighting, much more consistent and predictable air setting, much lower air setting, longer burns, more heat, less smoke on startup.
For some woods, (i.e. oak) this is more pronounced, but unless you have a perfect drying setup, I'm sure it's noticeable with all hardwoods, certainly the ones I've tried; oak, maple, hickory, cherry, tulip poplar, birch, locust and dogwood.
TE
Of all my jerry rigged greatness i never would have thought of such a simple and cheap solution. Lol...thats a good idea.Better yet, use better quality shower curtains when they get too grimy from the shower, then you get several years of a second life out of them.
