BeGreen said:No. A pound of pellets and a pound of good dry wood are roughly equivalent in heat value ~8500 btus. But a cord of very dry oak will weigh about 3500 lbs. vs the 2000 lbs of pellets. The pellet stove will burn more efficiently, maybe as much as 10-20% more, but not enough to come close to making up the difference.
enord said:Softwood 2-3,000 lb/cord 10-15,000,000 Btu/cord
Hardwood 4-5,000 lb/cord 18-24,000,000 Btu/cord
Sawdust - green 10-13 lb/cu ft 8-10,000,000 Btu/ton
Sawdust - kiln dry 8-10 lb/cu ft 14-18,000,000 Btu/ton
Chips - 45% moisture 10-30 lb/cu ft 7,600,000 Btu/ton
Hogged 10-30 lb/cu ft 16-20,000,000 Btu/ton
Bark 10-20 lb/cu ft 9-10,500,000 Btu/ton
Wood pellets - 10% moisture 40-50 lb/cu ft 16,000,000 Btu/ton
Hard Coal (anthracite) 13,000 Btu/lb 26,000,000 Btu/ton
Soft Coal (bituminous) 12,000 Btu/lb 24,000,000 Btu/ton
Rubber - pelletized 16,000 Btu/lb 32-34,000,000 Btu/ton
Plastic 18-20,000 Btu/lb
Corn - shelled 7,800-8,500 Btu/lb 15-17,000,000 Btu/ton
i also have have fuel cost calaculator link below as part of my signature
dont forget to vote for mme @ other link below.
BeGreen said:There are lots of variables ml. You'd need to look at the stove efficiencies, fuel, blowers, the house (any insulation, caulking, weatherization changes) and the degree days for the winters involved. If I heated our house exclusively with pellets (when we had the stove) it would be about 4 tons. Our pellet stove did better than the woodstove (F3CB) in general because it was more efficient, much more centrally located, has a blower, and all along I have been tightening up the house. Finally, when we got a cord of less than perfectly seasoned wood, the pellet stove easilly outperformed the Jotul.
hearthtools said:1 1/2 cord of hard wood = 1 ton of pellets
hearthtools said:I look at is as 1 an 1/2 cord of hard wood = one ton of pellets for heating
but you can put 2 tons of pellets in the same space as a cord of wood.
BeGreen said:It is the opposite. 1 ton of pellets = about 56% BTUs of a ton of hardwood
1 cord of hardwood = ~30,000,000 BTUs (8500 btus x 3500lbs)
1 ton of pellets = ~ 17,000,000 BTUs (8500 btus x 2000 lbs)
If the wood in the cord is higher moisture, it weighs more but gives off less btus, but the math is the same 8000btus x 4000lbs = 32,000,000 BTUs
Where the pellet stove narrows the gap is efficiency, but not enough for parity.
It all depends on the type of hardwood....johnnywarm said:BeGreen said:It is the opposite. 1 ton of pellets = about 56% BTUs of a ton of hardwood
So its 3,000lb of pellets to a cord of hard wood---??
zeta said:I copied the quote below from http://www.pelletheat.com/core/aboutPellets/
"One ton of wood pellets has the heat value of about one and a half cords of wood...."
9th line down in the bulleted list via the link above.
GVA said:It all depends on the type of hardwood....johnnywarm said:BeGreen said:It is the opposite. 1 ton of pellets = about 56% BTUs of a ton of hardwood
Be Green I think 30,000,000 is a bit high for what 90% of the burners actually get unless its a fruitwood....
I would scale it back to 22-26 mil BTU for the avg Joe
