Last year, I remember a fairly vigorous debate on hot water circulators. I have a big problem with the fact that these are often billed as "green" devices when in fact they spend a lot of time keeping pipes hot when water isn't being used. No doubt they save water, but they also waste heat.
That being said, with our recently added solar HW system adding about 20 feet to our total hot water supply distance, I am looking to allevaite this delay as I hate to throw the cold water down the drain waiting for the hot water to arrive. I do understand the motivation.
Having done some more looking around, it looks like there are a couple really nice solutions out there that recirculate on demand, and easily mount undersink. These alleviate my concern of circulating hot water whether you need it or not and seem to be a much "greener" solution to the problem. The main drawback I see is you have to press a button when you go into the bathroom in the morning to trigger it, or while you load up the dishwasher, for example, and it will still bring the water up to temp much faster than a low-flow faucet or showerhead. That's a simple tradeoff I'm happy to make to save oil in the winter when solar isn't doing the job 100%. (and if that's too much work, some even offer motion sensors so by the time you've undressed, the water is hot![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
My other concern with these was that they are not cheap and I need to be able to trigger it from our master bath, or from our kitchen - the two main places we often need to get hot water. Well that problem is apparently solved - they now offer RF wireless switches for about $20 that let you actuate it from anywhere in the house. Since our kitchen is on the same circuit, this looks like it may do the trick!
From what I've seen, I'm leaning towards the Metlund systems:
http://www.hvacquick.com/mtpmconfig.php?fm=S50
but there is also a similar competing model from a company that also does a thorough job of debunking the problems with systems that run on timers or 24x7:
http://www.redytemp.com/
If anyone has experience with either, I'd be interested to hear it. There is a third system called Chilipepper that is cheaper but a couple things I read said it is very noisy. It looks like either of the above two would do what I'm looking for.
One other interesting point I read on these was that you have to be careful with oversized systems that push too hard to keep hot water ready at all times. In some cases, esp. commercial installations that aim to always keep the lines hot, the flow velocities are far too high and they ultimately degrade copper pipes from excessive turbulence. For that reason, I'm tempted to go a little undersized on the device even if it takes a few seconds longer to exchange with the cold water return to bring up the hot water... the plumbers that did this place weren't exactly top notch and I don't want to stress their handiwork![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
-Colin
-Colin
