Older Wards Franklin Stove
AKSean
2
My grandfather purchased this stove used in the late 1970s and it heated his little home for10 years. Its been in storage and I am thinking of restoring it to use in my Alaska cabin. It would not be the primary heat source. It has all its parts (the doors et all are removed in the photo), just some new mica. However, in reviewing other posts, I am concerned that those of you in the know might suggest that I should destroy the thing and get something newer. I don't want to make a mistake. It has a Montgomery Wards emblem on the back. Your thoughts are welcome. Thanks
  • Older Wards Franklin Stove
Welcome Sean. The stove appears to be in decent shape. If there are no cracks and everything works well it might be fine for occasional use in a cabin. How well it will work depends on the cabin size, time of year and the number of days you will be heating. The stove will need generous clearances to combustibles and a proper flue/chimney + hearth to be safe. Is there a UL tag on back specifying clearances?
Thanks, no cracks or significant corrosion and unfortunatley no UL tag. I'll play it safe. I'll consult with a local installer on the flue chimney. Thanks again.
