Older Thelin Parlor 3000
Onesolar
2
Arizona
I have 2003 Thelin Parlor stove with a feed problem. On high it feed to fast and will shut off on high flue temp.
it will do it on med sometimes but not always, Low is fine , I see trim pots on the control Board ,but the board is not the board they list on the online manual. I need a diagram of the older board so I know with pot to adjust. BTW my trim is turned all the way down. Anyone have a copy parts placement of the old board they will share?
Also Thelin support is basically worthless. Just Saying
wish i could help ya with the Thelin manual dont have one , but i think Thelin isnt still up and running as a company unless they sold , last i had heard they were selling the business
if you look at the board it should say lofan and hifan right next to each trim pot. On my 2006 Parlour the upper is low and lower is high and they sit right above the jumper on the circuit board. My board is marked with the part number 43000-03 on the lower right corner.
here is a copy of my manual in pdf form, hope this helps
